looks like the clients gone for the idea so here’s a cursory update - after a couple more hours work.
(thanks to someone here for the ‘velluto’ material).
I’m gonna create a series of QTVR’s with sound etc…so here’s an initial pass.
some nice work there but personally, even though this is artificially lit, I think it would look better with more brightness and contrast and possibly a bit more glow. Crank up the lighting so the lit areas next to lights are just starting to be bleached out. This is just one opinion though
I agree entirely, although at this stage Im just trying to get the room designed up / materials etc… Here’s a quick P-Shop tester ..‘maybe more along the lines of what you mean?’ Persumably i would render with linear mapping + some post blur for the burn effect..? Advice is appreciated.
The reason I am raising the question of these people is that they are MY people! I created most of them and I want to know exactly how you came about them.
Which people are ‘YOUR’ people mate?
Could you specify please and then I can look at the file properties and try and find out a bit more.
More then likely they will have been given to me by one of the many people I know in the industry, who in turn will have been given them, who in turn will have been…(you get my meaning)
I have to say i’m suprised at your response generally, given that I’ve lost count of the amount of data I’ve shared with people over the years.
I am happy to share data when it is done above board and with my consent. The people I see in your images are from a library series called Imagedisks. I have compared the images from your portfolio with the library database and established the following examples:
Exterior images - Image 0
All three people used in image are from Imagedisks
Exterior images - Image 5
All four people used in image are from Imagedisks
Exterior images - Image 6
All nine people used in image are from Imagedisks
Exterior images - Image 7
Exterior images - Image 9
All six people used in image are from Imagedisks
Interior images - Image 5
One of the two people used in image is from Imagedisks
You should take your position a little more seriously. Each Imagedisk library came with a legally explicit and binding contractual agreement. Using the images outside of these conditions represents a fraudulent act.
Do you have any further comments to make before I bring this matter to the attention of our solicitors?
