I seem to be getting black dots on my red shiny chairs also the quality of the tree on the left hand side isn’t that great either it looks a bit grainy. The subdivisions on the glossies on both is 50, does anybody have any ideas?
I’m using Max 9, Vray 1.5, Phy Cam, Vray Sun and Sky.
Any comments and crits as well please as it’s WIP. Thanks
if it’s LWF you need to tick “Dont affect colors” and set the Gamma to 2.2 in the color-mapping rollout. that should help a lot already. If you dont then VRay will sample sRGB tho the output is linear. Wich means that it does WAY undersample because to VRay everything seems rather dark.
I was under the impression that if the below were my setting in my preferences/gamma rollout I dfidn’t need to set gamma as 2.2 in the colour mapp rollout?
Sorry for all the posts but I have a major problem now, I haven’t changed any of the setting except upping the resolution to 3500 pixels wide to render over the weekend and this is what happens. Nothing appears when it is building the light cache and this appear when it is doing the irradiance passes?
It renders fine at 2000 pixels wide, I’m not running out of RAM.
That kind of VFB display means you are just at the edge of a crash because of lack of memory. So you have to conserve some memory.
Besides it helped a lot already. hard to tell with a compressed jpg. but even in the jpgs if i put the nect to each other in PS there’s a lot less highfrequency noise in the images. You will most likely have to boost AA sampling a little as the noisy parts are rather dim and hence not sampled enough. just raise the minimum samples i guess.
Set in Max preferences/gamma rollout bitmap files - Output Gamma to 1.0,
Incresase LC sub from 300 to 1000, number of passes should be a number of cores /In my dual quad xeon 5355 is 8/
Also try global sub. mult. from 1 to 3…
The lighting from the candles looks to white and probably to much… looks like overhead lighting… i would add some type of flame at the top of the candles and tone down the brightness…
Also, if you have these tables set so nicely, I would think there would be some silverware and maybe a napkin too..
The building on the right looks like it needs some floor plates… noticeable at the top left side…
I’ve had to finish another project but am now back on this one. I’ve done all the changes you have suggested, upping the global sampling to 3 and all the rest. Overall the image looks a lot cleaner and crisper but I m still having a major problem with all the close up models on the tables and the red chairs.
They are just standard evermotion models to save time so I know it’s not the geometry because i have used them on other projects.
