Hello everyone… this is a WIP of a living room. I still have to change background and the glass on the windows. Probably ill b adding more elements into it. suggestions and comments are much apprecated. thanks.
A good start, well balanced, mabee a little too grayish..
The sofa looks like a tastefull marshmallow..
hummmm.. yummy
The bump on the floor feels a bit too heavy. The exterior background photo is nice, but looks really underexposed (but you mentioned that you were still working on that part). The corner of the couch looks like it has a texturing error. If that’s a plasma or flat-panel on the wall, then it looks really dim, like it’s not backlit.
Also, the props on the left wall near the window look like they’re being lit with a slightly hard light source from below the window. If that’s just natural daylight/sunlight coming through the window, I wouldn’t expect to see the shadows casting in that upwards direction.
i am still having a problem with the furniture selection.
the curtain certainly needs sme improvement… we are on the verge of exploding in our pants to get the proper refraction, even if we check the affect alpha slot,still there is no alpha if we use refraction with glossiness…
Regarding on the plasma screen, hehehehe, my bad… i used vray material for the screen glass and i guess vray doesnt cooperate much with refraction. thanks for noticing and i will give it another try… And yess… the floor sucks. i agree that i should need to improve on the bumps.
@ theblanch: :lol: u are right… you made me remember breakfast all of a sudden… hmmm. marshmallows.
Thanks for your comments… try to note everthing and i hope that this will turn out rather well… peace.
