hi all!
this time im want to hear c&C from all of you before i finish the project.
stephan
hi all!
stephan
very nice. Did you use HSV color correction?
Good start, but you should fix your texturing (repeating pattern is showing). Also the color bleeding to the white building appears to be quite strong.
Green bricks??? :shock:
Is that a bug or a feature?
Mirko
Looks good but the shadows are a bit hard edged and the backdrop is too low res.
What’s wrong with the background image, it looks like a small .gif file from internet.
Oddly, this looks like a photo-real version of a Giorgio De Chirico painting…
thats the final..
Very good work as usual Stephan. The patchy colouring of the brick works well - is that in the texture map, or is it something you’ve done in post? Do you still use HSV Exponential colour mapping for your exteriors? Last time I tried to use HSV for a brick buliding, I lost all definition in the brick work and it just looked like a solid colour from a distance. Ended up using Linear, which worked ok.
Nice image…the floating ramp is a bit disturbing though.
Well whats missing still,
i think you should put some glossy reflections on the bricks. also you could take your bricks textue to make some stones more ore less, also more ore less glossy reflecting. This is something that would improve quality . thare are no materials out there that do have no glossy reflections (expect of glas and chrome).
hmm, texture repetition also, could be improved, and the contrast is a bit low i thing.
but overall a good start.
good work! i like it. can you let us know what the building is for?
its nice,
a little bump on the floor maybe.
what is it for a grat tree?
