Wire constant value to IOR slot or float value??
Hi all can anyone show me how to wire up a material in slate so that i can put in some kind of float value node? not one type of controller can be wired to IOR slot. i want to do this like in unreal engine where you put in a constant value. doe that make sense? see image i tried to wire these to IOR it does not allow any of them.
is this how use output node?? thanks
or do i used vray user scaler ? thanks
If you show the “Additional Parameters” of the VRayMtl, you’ll be able to plug in the controller there.
ok thank much
