I would like to Wire some Noise parameters which was set up as Diffuse Map.
But it looks like Corona does not let me to go so deep when I try to reach the Noise Level.
Is it a known issue and is there any workaround about it?
Thank you!
Dmitry
Hello, it looks like there is a problem with this for every Corona mtl. The temporary workaround would be:
-create a new “standard” (non-Corona) material
-instance the noise/whatever map from Corona mtl into this material’s diffuse
-wire this
-apply the Corona mtl again
Great!
Thank you for the tip maru!
