wireframe to smooth+higlights
In some files when i switch from wireframe to smooth+highlights mode (F3) Max 9 64bit continue a crashed…(win XP 64bit),
hardware used: dual xeon 5160, 4 gb ram, geforce 8800 GTS
Same problem in Max 9 32bit on win xp 32bit, hardware used: dual xeon 3.4 Ghz, 2 gb ram, quadro fx 1300…
All material are Vray
Both system are running with direct3D (recommended) display drivers.
In open gl works fine but extremly slooow…
It is Max 9 problem or Vray?
thanks everyone for help
Try changing your video drivers.
8800 GTS update today with new driver…
thats must be the origin of ur problem i suppose then!
