Wish: approximated time for calculation an animation
could it be possible to show the time until the calculation of an animation would approx. be finished? Maybe based on the used time for the current count of frames.
-Micha
@Micha this feature is planned. Got your +1 :slight_smile:
Great! Thank you.
Is there a way to see how long an exported animation took to render?
Hey @vjaramillo_cg , this is currently not possible I’m afraid. I’ll happily file it as a feature request, but could you also quickly let me know what your use case scenario(s) would be for this? :slight_smile: Thanks!
It’s one of the things mentioned here: Video Editor improvements
@Gadget_1 I don’t think that you’re asking for the same.
You asked for the estimated time, he asked for possibility to see the taken time after the rendering is finished.
It helps with estimating how long a job will take to complete. If I know that each animation sequence takes 10 mins. and I have 3 cameras to export, I can tell my client it will take 30-40 min to render vs guessing. I use it all the time when creating projects in 3ds MAX and vray.
I’m too interested to know the render times needed for an animation. Often a preview is calculated and based on the times the final output time could be estimated (higher frame rate, …). Helps for tight deadlines. (Additional to an approximation during the animation is calculated. Rhino|Bongo support this both features and the are very helpful.)
Topic got your upvote.
What’s Bongo?
Bongo is the animation tool of Rhino3D. You can setup animations and render per every render plugin you like (except Enscape :frowning: ).
