if I select two independent area lights than I can change the intensity at the object properties and both are update. But if I select the two lights at the asset editor than only one is updated.
-Micha
-Micha
If you select multiple lights in Rhino and change one of their colors in the Asset Editor - all will get updated.
And if you select lights at the Asset Editor, can you set the same intensity?
