Wish List
2 days into using Vantage. Points id’ like to see developed more if possible.
1. Live linking from Max, frozen or off objects are seen which isn’t good.
2. No over ride material in vantage. I like to render previs videos in vantage in white override.
3. Animated camera paths from max to vantage needs a lot of work. Was using within max a path constraint camera on a spline. Heavy file. Recording in vantage was very poor even using a 3090 graphics card.
4. ctl S didn’t seem to work for me
Some of these items may already be in the pipeline. I like the interoperability between max and vantage. much better than other platforms, but has a long way to go to surpass competitors
If you’d like more info on the above, please let me know
Hi Troy,
Thank you for the feedback.
Why frozen objects wouldn’t be visible? Have you tried if the result is the same when rendering in IPR with V-Ray? Hiding objects should be propagated in the live link and should update accordingly in Vantage.
Yes, we have that issue logged but no ETA. AS a workaround you could export the scene from max with an override material and import that in Vantage. If you have made vantage file you can use the File>Open Scene as Config Only to load any changes or camera animations that you’ve made.
Can you explain more here? What do you mean a heavy file? Have you made an recorded camera in Vantage and the movement was not good?
We will look into this.
Alexander
Thank you Alexander for the prompt reply. I will endeavor to respond to your third point over the next day or two.
