It would be very helpful if median, mean, max and min were reported with the legend when running the lx and cd grid lighting analysis.
thanks for considering it.
Jeff
Jeff
Hello, Jeff,
Thank you for this suggestion! I will log it for further internal discussion.
Could you please tell more about the workflow you currently use that includes the Lighting Analysis render element?
Kind regards,
Peter
Hi there, concerning the lighting analysis element, I’m trying to do some basic lighting calculations that don’t require DIN conformity in SKP with VRay. For this, it would be great to create a plane object, for example a square or polygon, and measure the lighting data (illuminance, luminance) on that specific plane, with minimum, average, maximum, and the uniformity: min/average lux level. Having such a measurement plane would significantly increase the workflow for lighting designers.
Speaking of luminance: just to make sure: the luminance values displayed are in cd/sqm, right? because in the UI it only says “candela”…
Best regards
Oliver
Tobias Lichtplanung
www.tobiasink.de
