Are there any plans to allow us to type in entries for settings, or is the slider the only input Enscape will allow?
This has been mentioned several times as potential solution for various problems but I do not see a thread about it. I also do not see this on trello.
Thank you,
Chris
Ryan_2
2
Like typing in a value for field of view for example.. yeah I agree, it would be nice.
@Ryan_2 @renderwiz Currently you can only use the slider or manipulate the setting.xml manually.
The topic is on our agenda and got your upvote.
aw man, you’ve almost stolen the show of my big reveal!
Micha
5
@Jonathan_Knoefel Where can be found the settings.xml? (I’m using Rhino)
My Documents/Enscape/Settings
(MyDocuments/Inreal Technologies if you started using Enscape early)
You can try to modify these files, but we do not support it officially.
The current preview lets you enter numerical values, but it’s a bit clumsy:
you have to click on the setting (*),
click on the [ellipse button] beside it to call the menu,
click on the set value option to bring up a popup dialogue,
click on the value shown in the text entry box(**),
type in the value,
and click somewhere else to set it (***)
… the entry box vanishes and slider changes.
The value still displays in round numbers, but the actual value is recorded to two decimal places. (54.51 shows 55%)
(* - not strictly true: you can just roll the mouse over the setting.)
(** - not strictly true: the box pops up with the existing value highlighted and you can just type to over-write.)
(*** - not strictly true: you can hit [tab] or [return] to set the typed in value too)
