with displacement " updating instances" hangs
hi,
if i enable displacement the calculation hangs a very long time at “updating instances”. it shows “done” but the green processing bar always runs from left to right. it needs quite a long time to begin with the rendering.never seen this before.
vray 3-30-03 max 2016 sp1
thanks thomes
What is the setup of the displacement node?
What type of displacement is this 2d or 3d ?
Maybe the Edge length parameter is set to low ?
thanks tashko,
vraydispl modifier, 3dmapping, edge length 8 pixels, view-depend
Thanks.
Can you post or send the file to support@chaosgroup.com so we can check if anything is wrong with the setup or there is a bug?
I just waiting 1/2 hour watching the updating instance message. It is a displacement thing, at least for me, because if I globally turn it off there is no wait.
