Wondering if I'm importing fbx file wrong?
I have a problem when trying to add corona materials to an imported Revit fbx file.
It seems I’m importing incorrectly because when I select objects, such as walls, to apply a painted color or plaster, the selection says “Gypsum wallboard” which is the layer applied in Revit. And ALL of the walls are selected. I’m told I should not be selecting materials to apply materials to. So, apparently I am importing the files wrong??
I feel like I need to learn the process all over and I don’t know where to begin.
Any advice out there?
You’re not doing anything wrong in Max. Your file was combined by material on import. When a Revit model comes in through Link Revit / Link FBX with the preset set to Combine Entities: By Revit Material, every element that shares a Revit material becomes one Max object, named after that material and put on a layer of the same name. I think that’s why “Gypsum wallboard” selects all the walls at once.
You can Re-link with a different preset (File › Import › Link Revit or Link FBX, then the preset’s Combine Entities setting). By Family Type gives you one object per wall type, keeps the Multi/Sub material IDs and stays light. Do Not Combine Entities gives you every element separately; it’s the most flexible, but heavy on a big model. You can’t change the setting on a reload, so make a new link.
After that, assigning a Corona material per object should be exactly what you want, and you can also detach and then reattach by material using scripts if you want to speed up the process (I personally use Sini, but there are other free options).
Thanks Alessondro. I already tried using a new link with do not combine entities. And keep max materials on reload. Confusing results because now, not only are half of the objects red in IR, but when I select the glass on the windows, and apply a new corona glass material, they are still red in interactive renders?? The further I go the more confused I get.
I should add that I really dont know what to do with all of the errors when I relink. There are about 30 warnings that “Autodesk hardwood is not a recognized material.” “Autodesk generic is not a recognized material” etc.
I have the poliigon material converter but not sure how to use it.
Autodesk materials are not supported, and revit materials are mostly autodesk generic.
after importing, press “x” to open a search menu, search for convert and choose scene converter (no need for external converters).
By using 3ds max scene converter before corona converter, you keep your maps linked.
1 by 1, add the material that needs converting (source), add the rule (physical material). Also make sure it does not change the render or changes to corona.
After converting, a standard physical material is created with the maps, following the new rule.
Press “X” again, this time choose corona converter.
Now when you use corona converter, your materials get converted to corona materials and they keep the bitmaps linked.
Thank You Victoria
I have the poliigon material converter also but I’m not seeing how to select the correct autodesk materials. But the corona material converter worked great.
