Wood Close-up
Hey guys,
I’ve been playing a bit with corona, I am a native vray user.
I had some issues in this project with controlling DOF, I could not get it where I wanted, I tried changing the Corona Camera settings, the settings in the rendering tab, but still it would come out in the same position and at the same strenght.
I ended up using the standard Zdepth pass as a map in photoshop lens blur.
Would be great to hear some advice on DOF.
Hello!
How to enable and control depth of field (DoF) in Corona?: https://coronarenderer.freshdesk.com/support/solutions/articles/5000516203-how-to-enable-and-control-depth-of-field-dof-in-corona-
If you use a camera for setting of DOF then need to add CoronaCameraMod to Camera and check ON and set up DOF there is
Hi. I think it looks like the bump (noise?) are a bit to strong on 01. 03 is better :smiley:
