Hi guys,
any idea how to make this shader?
it isn’t tileable.
I was thinking to use substance designer but i very newbie with it so i don’t know if there is a way to use different image of wood and use it blended with a cell pattern.
Or is better to makeit with geoemtry in 3ds?
You should be able to do it easily in Substance Designer with Cells 4 and a parquet pattern. I haven’t touched SD in awhile, but if you asked on the Allegorithmic forums I bet someone could figure it out in no time.
