Hi, guys, I’m finishing a project here and I would really appreciate your opinion while I don’t show to the client. Thank you!
Rendered with Corona 1.0 and 3ds Max 2015!
Theres a lot more to come! A lot of angles! :)![]()
Should be moved to the WIP’s if it’s incomplete.
Add some subtle fog, and take care that the grass won’t be growing through the terrace floor.
Nice, but way too much chromatic abberation.
Definitely too much contrast and effects. Showing a raw render would make it easier to judge.
I’d use warmer interior lighting with the contrast of cold blue global light for the starters. Dunno maybe it’s just for me, but the bright white lights doesn’t work .
here’s an example of what kind of colour scheme i’m talking about.
http://c1038.r38.cf3.rackcdn.com/group5/building43503/media/kujk_dezeen_aresolbringenbywaldemarsonberglund_ss_7.jpg
I tried to achieve this but in this image there’s no trees and in mine theres a lot. So became different. If I let the ground white and take off the trees basically would be the same.
Man, had already post processed hehehe. But I liked your color correction… blue tones… and the contrast. Though a bit too much. But nice!!!
It is just a sugestion to give it more of artistic look.
The contrast depends on monitor. I am using Dell U3011 ajusted for glossy paper print.
Thank you man! Thanks for the attention and to help me. Great help you gave me. ![]()
