Work around for floating license?
I was recently in a secure facility and wanted to show off Enscape’s capabilities. I did not have access to wifi or even my phone to use as a hot spot. If I understood the message I was getting, Enscape could not “authenticate” my license because it could not connect to the internet. Is there a way to avoid that with the floating license?
@dsiekman you need a internet connection to verify your license, afterwards you can use Enscape 24 hours without an existing internet connection.
If you can’t manage it this way I would recommend you to add a fixed seat license which only needs to be activated once for their term.
Okay, thanks. I had closed out of it at the office on my workstation but had not opened it on the laptop prior to leaving. Next time I will.
