Work: Interior
Hi…it’s been so time since my last post here, 'caus i’m really busy now…
This is my latest work. The mistakes are for the short time i’ve dedicated to this work (approx. 2/3 days…)
C&C are welcome
Valerio
:slight_smile:
Well still no replies, but im shure there be some feedback
on these one it´s nice atmosphera due to nice ligth and good estetic.
Crtics? - the bed clouths seems to hard or …
And thats all cause the rest looks flawlless. :roll:
Yeah, i agree with you. Due to the lack of time i used Reactor, but i couldn’t test it so much. Next time i will try simcloth, that seems to give great results.
Thaks for you comment.
Valerio
Very nice :smile:
good lightning
congrats !!
Vince
Thanks.
Lightning is quite simple…
1 direct outside+skylight
3 area at windows
and 2 IES by Erco on the wall (1 is out of view…)
Valerio
nice,
could you do one more without the uplight? I think that would look more natural.
regards,
robert
Great render Valerio, congrats!!!
bye
Neo
:shock: 8) :smile: :smile:
peachy render, looks very stylish, where did u get the paintings?
Thanks everyone.
@ Robert: this is a part of a complex building i’m currently workin’ on. So at the moment i can’t plan to make other render on this room. When i will have more time i will make other view, also without artificial lights.
@ Roark: this painting are downloaded from this site
http://artchive.floridaimaging.com/a/
change the “a” to obtain other ones…
The side is down at the moment… :cry:
Ciao Valerio
You bastard! So you’re the one who stole my paintings :lol: :lol:
http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=5099&highlight=table+simple+interior
Very very nice rendering :shock: What happened with the colored version?
ahahhahah…you’re right, i searched these painting after see them on your render (impressive one!)…
Colored version stays on my HD!
My signature is black and white!
Ciao
Valerio
I’d been interested in knowing more about your lighting method.
Why use both Skylight AND area lights @ the window? Are you using the area lights with Skylight Portal option turned? If not, could you not get enough light in to the room with just the skylight & the diretional light and then use colour-mapping instead?
Yeah, i use area @ windows, but i didn’t use Sylight portal, only “store with irradiance map” to spped up.
You can obtain good illumination with only Sky+Direct but you have to increase the Sky 'cause glass stops it. And this makes burned outside.
Valerio
:!: About reactor and simclouth i really prefer the last one.
Thanks holyghost, i didn’t realise that glass blocked illumination from skylight.
Does anyone know of a workaround to this problem?
great work…asd … eehehehheheheheheheheheheheheeh
Grazie Max! ahahaha
@ Mohineder: there’s the solution inside Vray. Use Skylight at the windows, also look at the function “Skylight portal”… :wink:
Valerio
great work! :smile:
Impressive lighting! But I think it will be better to give the walls more space to breathe!
what type of shadows do you use? I am a newbie.
is this shadow map or vray shadows?
