Workaround: stable view angle for screenshot output
I have the problem that every little unwanted change of the viewport ratio cause a different view angle of the Enscape output. So, after days it’s difficult to render an old view again.
Here a little workaround. Create a new button or edit the Enscape screenshot button (or better copy this to an other toolbar[Shift + drag&drop], since the next Enscape update could overwrite the button). Add this little script:
! _-ViewportProperties Size 900 500 _EnterEnd
_EnscapeTakeScreenshotCommand
So, before a screenshot is started the viewport is reset to a fixed size. The screenshot output size is still defined by the Enscape options, but now the viewangle stays constant.
Happy enscaping,
Micha
