Workflow for Vray Sun / Sky / Clouds in Solaris?
I am currently learning Vray in Solaris. I am familiar with the environment workflow and getting the sky and sun workflow working in the old OUT context. In LOPS things are different and I cannot seem to get it working, nor have I found anyone anywheer explaining it… Attached are some screen shots of the setup. I get the sun working but the background is either transparent or black. I tried making a material with Environment and Sky and applying it to the sun… What am I missing?
Here is are light settings
Hey @design_technology1 ,
You will also need a Dome Light where you can pass the Sun Light stage path under the V-Ray tab → Sky. You may also need to explicitly set the visibility of the Dome Light so the V-Ray Sky is visible.
As a side note, we are preparing a V-Ray Skybox HDA to simplify this for the future.
Best regards!
