Working freely while opening all panels from Enscape
Hi enscape team,
I would be nice if you can give the freedom as in Sketchup.
When I open material editor in Archicad, I cannot work inside Archicad unless I have to close the panel. In Sketchup, this is not a problem. But in Archicad, it is quite inconvenient to close and open material editor constantly.
@thinhpham - this was not implemented, as I understand there were some uncertainties involved in doing this.
I have filed a feature request, and if enough ArchiCAD user also request this, then it will get re-evaluated.
+1
@Tikos - Noted.
+1
+1
+1
Adding your further upvotes, thank you very much.
+1
This is right.
Especially with the materials editor which has to adjust to the workflow of the surface painter of Archicad.
When you choose an object the material editor must autofilter the materials that the object has.
Searching with the search or with the scroll tab is not an Archicad thing…
I would offer a +1 here too… but really need the AC 23 version first!
Adding your votes - as mentioned @DGD-Duane , it’s only a matter of time and our developers are very aware of the demand for this implementation.
+1
Added. Support for ArchiCAD 23 will be released with an upcoming preview, or with 2.7, but I cannot yet make any promises.
