Working space-Z
Hi all,
lighting test
Model in Sketchup
Enscape ver 2.5.3
Hope you like it
@QuangVinh-Zin , these renderings are just simply fantastic - the 6th image from above is now my desktop background! Great attention to detail, excellent choice of materials and high quality / polygon objects. The cat pictures on the walls are just the cherry on top! :smiley:
Thanks alot Demian Gutberlet,
I also like it like you, when ignoring the material, light will show emotion :wink: :wink: :smiley:
great work
Thanks tagounits samir
Wow - excellent again, both: in “craftsmanship” and rendering :thumbup: :thumbup: :thumbup:
especially concerning your first and the third scene camera ! :thumbup:
Whereas all other cameras are very redundant, at least for me.
What do you want to show? The workspace or an expensive watch with an expensive fountain pen?!?
If it is the workspace, the focused details claims the attention instead.
Thank you for your comments.
In the interpretation I wrote very clearly. This is just a light test in different cases such as sunlight and artificial light …, and test the performance of lamps in enscape. The title is working space is just an example project I used to test. Thank you for your interest :slight_smile:
… ok & thanks - prima in any case :slight_smile: :thumbup:
would be interested with the curtain’s map thb !! very well done
Which video card you using?
I am using the rtx 2060 super video card
Have you used any older cards other than this, sucha s the gtx versions? Im wondering if you can have this results with a GTX card.
Hi otacrema,
I used to run enscape on GTX cards for other projects but not in this project
Kindly write in English next so that everyone can read what you’re saying! :slight_smile: Simply make use of Google Translate for example.
