Working with high poly counts in Vista
I am creating an onyx tree for use as a vray proxy, and right now I am at about 18M polys…and this is stripped down to the bare minimum of what I need in it! I am in the process of attaching all of the pine needles together and when I do this VIZ just eats up my “free” physical memory. Vista by default is pre-caching ~5GB of my 8GB of physical memory due to SuperFetch, from what I understand. When I restart I can get quite a few of the needles attached before SuperFetch grabs ahold of the physical memory, but once it does, I have to restart again and fight/race Vista for my free memory. I have several more trees to handle in this situation, and I want to find a better way to do it.
1. Is there a way to disable SuperFetch temporarily?
2. Does a true 64 bit application, such as MAX 2k8 64bit, face the same struggle with SuperFetch over the free memory?(I am using VIZ 2k8 32bit)
3. Is there a simple way to clear the memory that SuperFetch is caching without a restart?
Thanks,
Ben
Are you using editable mesh,? If so Epoly may be better.
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=39399&highlight=attach+poly
Thanks!
EditablePoly seems to work just fine :slight_smile:
