Our team is working with worksession in rhino since the file is really heavy. But I have an issue that will happen sometimes: materials in worksession doesn’t show properly in render view when updated, sometimes all the materials are not shown.
I have to restart rhino to solve this. Can anyone help with a faster way?
Are the material changes visible in Rhino, but not in Enscape? Or are they not visible in Rhino, as well?
If the latter is the case, we probably can’t help you, but somebody from the forums may
If the material changes show up in Rhino, but not in Enscape, can you press the [Start] button a second time? This will trigger an update from Rhino to Enscape. Does this change things?
Thanks Kaj, I tried this solution, however it still remain undated.
Now when i update one link in worksession, all the material in that link will turn white in Enscape but look good in rhino. The only way to have them updated is to restart rhino. ;(
I’m sorry to hear about this then. Have you also made sure that you’re using our latest release? If that doesn’t help or you’re already up to date, then sending in feedback would be the next step - through the log files we may be able to troubleshoot the cause behind this behavior. In the submission form please briefly copy what you wrote in the forum here as well, or simply add a link to this thread for reference.
