Workstation Build Advice - 7985WX
Hello!
I’m planning to build a new workstation for work, and this time, I want a computer that will remain fast and reliable for a long time.
Here’s my current build plan:
CPU: AMD Ryzen Threadripper 7985WX
Motherboard: ASRock WRX90 Creator
RAM: 256GB (8x32GB) – I haven’t decided on the best option yet.
GPU: GeForce RTX 4070 Super 12GB
SSD: 4TB – Still deciding on the specific model.
Cooler: What would be a good cooler for this CPU?
PSU: Corsair 1200W
Case: Fractal Design Define 7 XL
Questions:
What can I change to make this PC better?
Do you think this build is worth the investment?
Thank you in advance for your feedback!
Looks good to me although given the specs I’d definitely consider getting a Threadripper non-PRO system aka something based on the 7980x instead of the 7985wx.
I don’t see you using any of the advanced features of the platform with that build - you have one GPU, 256GB of memory and a single SSD. So you don’t really need the extra PCI-E lanes of the PRO platform.
Even if you need “PRO” features like IPMI I’d still go with a 7980x and just buy an ASUS IPMI card I guess?
Main reason is that you’re really going to be overpaying for the PRO platform and won’t be using it to its full extent. Instead what I think could be better is using up the saved money for more SSDs, high end GPU with more VRAM and things like that.
That is unless I am missing something :smiley:
Oh and for the cooler I’d personally go with a Noctua u14s but just make sure you pick the correct one for the platform you have.
Thanks for the reply Nejc!
Great tip—7980X is better for my build and more affordable.
Maybe you can recommend what kind of RAM I should consider?
Also, do you know of any great 27-inch monitors?
