WORN WALL
HI GUYS I HAVE RECENTLY BEEN WORKING ON THIS IMAGE TO PRACTICE EXTERIORS AS I’M NOT THAT GOOD AT IT AND WANT TO IMPROVE MY TEXTUREING AND LIGHTING, SO I STARTED WITH THIS SEMI OUTDOOR SCENE. ANY USEFUL COMMENTS ARE WELCOME. (SKETCH-UP 7 PHOTO-SHOP AND AFTER EFFECTS)
Re: WORN WALL
It looks nice. Though the bump maps looks too strong. I’d make them much more subtle. Other than that it look really good.
(p.s. Could you please not type in all caps? It’s a pain to read. If you don’t care about capitalising, at least use all lower case.)
Re: WORN WALL
thanks for the comment Thumtom I by the time i realize i was typing in all caps i was too far was just lazy to retype. will try that any other comments are most welcome.
Re: WORN WALL
If I where to be really nit-picking; you could try to replace the grass in post with some real grass. But as I said, that’s really nit-picking. Maybe a slight warp in the glass. Finding it hard to comment on anything else.
I really like the warm tone of the light you got. Care to explain your light setup?
Re: WORN WALL
:)wow so amazing, i think for the trees you could put images of them, what version of vray ?¿ waht render time?¿
Re: WORN WALL
Sorry for the late response guys to answer your questions Thomtom the light setup is pretty much v-ray sky for the environment at default settings, default light checked and physical camera enabled with the settings of 125(shutter speed), 125(iso), 10(f number) and the rest left at default. after rendering the image had more blue than i wanted as i was going for a bright warm Caribbean feel so the rest was done in photoshop to add the color with color balance and i then added the glowing effect with after effects.
The version of v-ray was the first release and the render time was about 4 hrs as my laptop is not the fastest. and again thanks for the comments much appreciated.
Re: WORN WALL
Ah. I was very curious to how you got that colour tone. As you say, the renders often turn out rather blueish.
