However keep in mind that FumeFX has been around for much longer, so there is a wealth of information and examples readily available, with the respective workflows already figured out. This is something that won’t happen overnight for Phoenix, no matter how good it may be.
ChaosGroup has the best software, and support. But as far learning the software goes, that is one area where ChaosGroup is seriously lacking. Good to know however that you are working on Tutorials.
I’m new with phoenix and i wuold like to try some “liquid/water” effect for my next work.
I’m trying demo now… Do you know if thereis a BASIC tutorial to undestand how to generate water from an Hole? a simple animation like water from bottle to glass…i need to try someting before buy.
Thanks.
pouring water from a bottle to a glas is a relatively hard task, if the bottle is moving. the best way to init the content of a bottle is to use a geometry in brush mode. however, after the initialization, the liquid will start а transition process and eventually will settle. of course you can start the movement of the bottle skipping the transition process, i think this would be better. the animation of the bottle should be organized wery carefully, the movement should be slow enough or the spf value should be forced to high value, otherwise the content will pass through the walls due the “teleportation” of the bottle.
of course the whole task will be much easier if the bottle is static and the liquid is created somewhere inside it but outside the viewing frustrum.
