would you like a cookie?
i haven’t posted in a while.
just fooling around. comments are welcome
they look tasty. :slight_smile:
even with the green.
mmmmm cookie :smile:
Looks good.
hm cookies are great!
but didn’t didn’t like lighting and colors too much to be honest.
Lovely.
It also seems a perfect candidate for White-Balance.
I’d love to see the results of this once the heavy green cast’s gone…
Really nice , anyways.
Lele
don’t put food with green or blue color, because its look like bad food.
for cookies i would use warm light color.
looks yammi…
thanks for the comments I’ve adjusted the white balance. better?
the second one is better, but i think that you should have made two or three different cookie-textures.
I think that its a bit to easy to see that ist the same cookie but rotated.
(at least I think it looks like it)
Some crums would be nice.
But overall its a nice render
much better…
did you do this with the VrayCamera or as a post adjustment?
SV
I did it in post. it’s much easier. just a slide in photoshop.
I was just looking at the image on a CRT (I work on a LCD) and the colors are really saturated.
How often does this come up when you send work to people and they don’t have their monitors calibrated correctly. How do you convince people they don’t have their machines set right or do you?
I correct the color to fit the CRT (I’ll post it in a bit) and it looks pretty good on the LCD so is that the solution? don’t trust the LCD?
Much more balanced indeed, well done :slight_smile:
Lele
would I like a cookie? yes please!
Needs milk!
I think the cookies could use a bit more roughness to them. The edges that are cracks to the internals of the cookie shouldn’t be smooth, it makes the cookies look half-baked.
And crumbs!
Mmmm those are going straight to my thighs
Needs milk!
does need milk!
added some roughness to the cookie
also added a second cookie (yes it was one cookie spun around)
tried it with a pink background
Not sure I agree with the standard of not showing food against blue and green. I knew it was the standard but with a yellow or red light striking the food that should cancel out the bad food look and give it a color contrast. but…?
still working on the milk (it’s not so easy)
