Hello
This’s second time to test with corona render
i want to say i
it!
normal setup sun light and sky
200-300 pass render time 8 hrs.
model from Aleso3dและdesgin and connected
thanks
Thats a pretty weird way to hold a coffe mug. XD. The DOF is Corona made or Post?
Hey borisquezadaa,
thanks for comment,yes iknow look weird for the hand ![]()
DOF images no post production everything is corona
except put chomotic in photoshop.
cheers
Very good!
Thanks Coronaut ![]()
woww..like it …good mood,lighting,material…do you mind if you shared tips and tricks..maybe…sorry for my bad english..thank you
sure!
1.gamma i use 1.65 ,i think 2.2
2.exposrue 1.5
3.hightlight 100
4.contrast 1.05
5.white balance 7500
6.camera f stop 2.5
7.lighting
-sky multiplier 1.5
-sun intensity 0.75 rgb 214,140,60
thanks mate
Really nice work, perfect mood and lighting, the only thing which is weird is the height of the stair-rail. It should be really higher.
But otherwise perfect.
In the last pic you can see the geometry of the table around the edge, but apart from that amazing job! I’ve not created anything as photoreal as that yet, hopefully one day.
Hey O-mans, I think you brouht incredible quality!
Would you mind sharing your settings like lighting, gamma (1,65 or 2,2?), RGB value of white and post production workflow? Hopefully I am not too demanding! Thank you.
Great work.
Jakub
Sorry my mistake for a word.
i use gamma 1.65 not 2.2 i think 2.2 is too burn and out off control.
O-mans strikes again! Great images.
