This may seem trivial to be honest but it’s helped a lot in my workflow. In our pipeline we’ve been in Maya 2016, and we’re trying to move to the latest version. I need to make sure our workflow won’t be affected as we rely on legacy render layers, and we use a lot of layers. Recently I happened to notice (in Maya 2016) that vray wrapper materials had some attributes that only showed in the channel box for colorR, colorG, and colorB. These attributes caused the color of the wrapper to change in the view port which really highlighted what’s going to be visible and what’s not in the final render. Well I installed Maya 2018 and VRay 3.60 and I’m just doing some testing on a spare machine and I noticed that these attributes are gone. Again, I know this is trivial, but helpful. Does anyone know if it’s still possible to override the color of wrapper materials in the view port? (side note, I generally make anything with a wrapper pure green so that it’s quite obvious)
A possible workaround would be to change the default color of your object and then assign V-Ray material override with V-Ray Wrapper as an extra attribute.
It seems that the color attributes you are talking about is something that worked only in the legacy viewport. The legacy viewport was removed by autodesk in 2018 if I’m correct, so those will not work either way.
I would suggest the workaround that @nikolay.kusht proposed. Keep in mind it requires enabling the texture view (6 on the keyboard).
Will that work for you?
Legacy was removed but it can be reactivated through a quick edit of the environment file. Like I said, I am able to MEL script it so I can edit the colorRGB on the wrapper materials, but I do have to stay in Legacy Viewport in order to see it, which I’m perfectly fine with.
The workaround @nikolay.kusht suggested sounds like it would work in theory, but in execution might be a bit tedious in the grand scheme of things. I think ultimately I’ll live with legacy until they remove it entirely. In an absolute worst case scenario, I may be able to script in wireframe color changes with overrides per render layer, but it’s not my favorite option.
