Wrapper - shadow catcher working in one file, but not in an other file?
Hi
I have two files.
In file a, the wrapper / shadow catcher works as expected, it’s invisible, but catches the shadow.
In file b, i use the same settings, but I can’t get the wrapper material to be invisible.
I’m quite use I use the same settings for the wrapper in both scenes, but there might be some other settings I have overlooked?
Jorgensen
Hi Jorgensen_cg,
In order for the wrapper to function you have to be looking at the front face of the geometry.
You can try reversing the faces using the wrapper in the problematic scene.
If this doesn’t help, please share a stripped down version of the scene that we can test on our side.
Regards,
Konstantin
