Hi all,
I have a scene (call it scene A) and I set the autosave name on rendersetup like this “d:\autosave - corona%v -%o”. but the filename writed with wrong name .. it saved with name of scene that I work for months ago (call it scene B).
I tried to “resume from file”, yes it was right that it belongs to the scene A not the scene B.
and then I tried to reproduce it with many of scenes I have, and I got almost all wrong result, only one scene shows right result.
I remember that I never got this when still using the dailybuild, and maybe the RC-build still have the right result.
anyone got this issue? I’m still trying to find out why.
I think I found it.
the filename saved by corona autosave is stuck with max autosave (rendersetup>common>render output). otherwise, corona autosave will disregards the scene filename if there is a value inside a max renderoutput eventhough it has been unchecked.
I think if there is no any value inside it, corona autosave will works good. I hope the development team will make it unstucked with max render output.
and for the temporary solution, how to clear the value inside the max render output?? someone help me..
%o takes the name from “Render Output”, not from .max scene name. %f takes the scene name. The script works fine (you have to close render setup window!) but if the output path is empty then %o turns into “3dsMax”.
ah … fool me.
btw thanx for the script info romullus
