Wrong Gamma
Periodically one of my slaves renders with the wrong gamma. it’s intermediate and rebooting the slave’s spawner solves it, but why is it happening? It’s an easy fix, but after rendering all night just to see lighter boxes, is painful.
try blow away 3ds max prefs dir and see if that helps.
stopping/starting the vray spawner worked, and now it’s rendering correctly but it shouldn’t happen.[quote=“instinct, post:24, topic:39555, username:instinct”]
[/quote]
I get it happening every now and then. I don’t know what causes it but it seems to happen when I cancel a render and re-start immediately. It’s like the scene has failed to update or be sent over to the slaves for some reason. Annoying! If it’s persistent then I just re-start my local copy of max and it seems to work…
It would be good to know why this happens…
yes. I guess the workaround is simple enough, but overnight renders and deadlines makes it a huge issue.
Agreed. I ALWAYS wait around to watch my render kick off before heading home because of this issue but batch renders are another story… I can often spot the problem occurring during the IR pass which either means the IR map calc is the issue, or that we have a separate issue although it does appear like the slave is using the wrong gamma…
Do you use the option “Restart slaves on render end”, which should help?
yes. that is checked. I can start/stop dozes of times, usually without any issues, but once in awhile I’ll get this issue.[quote=“vlado, post:2, topic:39718, username:vlado”]
[/quote]
I’m exactly the same as above.
Can you try to use “Reset” irradiance map button the next time you see this issue instead of restarting the render slave?
And let us know if this solves it.
it’s happening again, now! How do I reset the irradiance map?[quote=“Micha_cg, post:3, topic:39727, username:Micha_cg”]
[/quote]
I am using Brute force and Light cache
The “Reset” is next to the Irr Map “Mode” select option where you select - Single frame, Animation prepass …
This will clear the irradiance map from memory.
but I am not using Irr[quote=“vlado, post:2, topic:39723, username:vlado”]
[/quote]
Ahh sorry!
Ok, will make some tests here, i hope to be able to reproduce this.
Can you specify the V-Ray build that you are using now?
I swapped to BF to see if it was a IR issue. So, I guess we ruled it out. I am restarted MAX, so I can’t check on the release now, but I will as soon as I can. I do know that it is the latest downloadable version.
I am running 3ds max design 2013 and vray 1.30.01 - I restarted my workstation and it didn’t fix anything so, it is a slave thing,
and it is my main workstation buckets that are rendering different (thanks to VRayDRBuckets). Rebooting MAX didn’t help so, now I am going to reboot the machine.
now, I have rebooted everything, and I can’t get rid of it!
It seems if I lower the resolution (for speed) and let it complete its render (even if I see the issue), it’ll render correctly the second time. So, the restart button might be working, but you have to let it complete the render first (makes sense).
