I have this issue, I am trying to render a 360 stereo panorama of a small room. THe problem is the the stitching on the top and bottom is not correctly aligned.
You can see the attached image, I have tried at different resolutions, and in Thow different computers.
I was using the latest version and then tested two earlier versions, but the problem is the same.
Any ideas?
Thank you
