I have a large building that I have to make 360s in many units. I created the building shell and a huge garden and other support buildings. I have made the intrerior units seperate and have xref the scenes. When I render the scenes seperate, they both render quickly and the light is correct. When I Xref them.. it takes forever to make an image and the light outside is correct and the inside is almost black even though I have a skylight, default light checked, and lights covering the windows set to invisible.
I have tried to import the units into the main scene and not use xref and it is still the same problem.
The other problem I have is I have a hundred rpc plants in the garden, every time I move anything even in wireframe.. I have to wait for everything to redraw. Is there a setting in Max that can get rid of this problem.. I am losing a ton of time waiting.
thanks
Michael
