Xeon 10-core v Xeon 12-core - advice please!
Without a farm, sure, I would rather have a Xeon box. If ALL I did was 3d (no 2d comping, etc.) then I would also want the Xeon box. If I also did a lot of 2d comping (motion, mainly, Photoshop is so fast on any hardware now that it doesn’t matter much) then I might go with two or three 5960x, which you could likely build for the same price as one dual Xeon (maybe even four vs. a pre-built xeon machine).
I think this machine will likely work out great for you. I wasn’t trying to instill buyer’s remorse…
With regard to viewport performance I was referring to playback, which involves animating things with the CPU, as well as the GPU. Complex rigs start to slow down, or many objects on paths, etc. In reference to RAM speed, the x99 motherboards let you use DDR4-3200, vs. the DDR4-2133 of the Xeon. This doesn’t make a huge difference in the real world, unless you are doing operations that move a lot of data from main memory to the cpu and back (compositing would be doing this more than 3d rendering, since rendering managers to get a lot to stay in the cache, though render can certainly take advantage of the faster memory, but I would guess a lot of dynamic memory items like proxies would benefit some as well.). You also have to remember that 28 cores (or 24, or 36, whatever) all accessing the same memory does cause bottlenecks. More cores is not a linear thing. Dual processors are even less linear than multi-core processors (though on some loads this can be outweighed by having more cache). It is really hard to make a good dual processor motherboard.
I really hope Autodesk optimizes more of Max! There are plenty of things that simply can’t be parallelized, though. I really wish Intel would work on clock speed instead of core count.
I am sure you will love your new box.
Let’s hope so - it’s been many years since there was any real innovation in max and that would certainly be a huge leap forward.
Yes, for me the vast majority of my time is spent doing test renders, and I almost never animate or do any kind of simulations, so this setup will work for me.
Just an update to say thanks to everyone for the advice. My system arrived a week or so ago and is absolutely screamingly fast, as I’d hoped. I’m doing full-res production renders in the time I was doing low-res test renders before… quite something!
Alex
So what exact spec did you go for in the end?
We have nothing but dual xeon machines here. Being able to do super quick test renders without resorting to DR speeds up my work sooooo much. Most of what I do seems to be sitting waiting for renders to finish so spending £6000 on a machine is well worth it.
Enjoy your new machine Alex!
Cheers Peter. It’s made a whopping difference to the amount of time I’m spending on test renders.
Resolution: I went for the following:
3XS GW-HTX30 Scan Base BuildASUS/Z10PE-D8/WS
Intel Xeon E5-2670 V3 s2011-3 x 2
Corsair H80 with SP120 Quiet x 2
32GB Cruc DDR4 Server (4x8GB) x 2
256GB SSUNG 850 PRO SSD
LG BH16NS40AUAU10B 16x BLU OEM
MS Win Pro 8.1 64Bit
FD-CA-DEF-XL-R2-BLack Case
3XS RM1000W GOLD CP-9020062-UKTotal was around £3800+VAT.I did spec up the slightly faster processors but the price difference was massive and they came with less cache. For the faster processors with the same amount of cache the price was enormously more. I think this config represented a really good bang-for-buck. Compared to my i7 3930k @ 4ghz this thing is stupidly faster. Having so many threads means that huge chunks of the image can be rendered even when other buckets get stuck on complex areas. Frees up so much time!Very happy with it so far. Service from Scan was very so-so, however, and there are issues with some dead USB ports I need to deal with. They seem totally disinterested in fixing them.
I have always been a dual Xeon user but I was thinking of going for the overclocked i7 route but I don’t think it is going to be much faster then what I have now and that it is worth it to go the dual Xeon route again. Are you going to overclock them and get that extra 10/15%? How noise is the setup at full load?
It has been an interesting thread, thanks guys.
Renato
These new xeons are not overclockable. The whole system is very, very quiet even under full load. Quieter than my 3930k@4ghz with an H60.
I read some where you can increase the BCLK and it gives you between 10/15% increase in performance. This is probably nonsense.
My warranty would be void if I overclocked this machine anyway so I’m steering clear! :slight_smile:
What graphics card did you get?
Using my old GTX770 4gb.
Curious how your performance has been with this system after you got it? I’m looking to replace my aging xeon 5650…:slight_smile:
It’s an absolute monster. Rips through renders. I’m churning through full 5kx5k renders with loads of planting and glossies in under 15 mins in some cases. It’s made a massive difference to how I work, actually. I’m now doing full res renders through the day, just because I can. Means I don’t have that last minute stress needing to push out the full res finals at the 11th hour.
Great! I’m most certainly going to replace my main system, but I have doubts about the performance of the current servers, only being twice as fast as the 5650 xeon. Twice as fast is nice, but I’d expect in six years to have higher performance then that. And there are 18 core cpus out there, but they cost an arm and a leg :slight_smile:
Yeh this is why I went for the 12 core processors. They seemed to represent the best value for money and you avoid all these NUMA issues with windows/max that Peter and others are having to suffer with. I’m more than happy with this new machine, definitely. It’s actually quieter than my old 3930k @ 4ghz with an H60 in it as well… there are 2 xeons in this, with 2 H80i coolers… very quiet box. Almost inaudible from 1 foot away.
Pulling the trigger on this setup (thanks AlexYork) your post has been super helpful:
x2 Xeon E5-2680 v3 30MB 12Core 2.50GHz LGA2011 9.60GT/s
x2 be quiet! Shadow Rock 2 CPU Cooler
x4 Crucial Memory CT16G4RFD4213 16GB
Fractal Design Define XL R2 Titanium
Intel 730 Series 480GB SSD SSDSC2BP480G4R5 2.5IN SATA 6GB/S
ASUS Z10PE-D8 WS SSI EEB Server Motherboard Dual Intel Socket 2011-3
nvidia gtx 780 ti 3gb
corsair psu 1000w
Final specs might change but man its gonna be sweet!
Pleasure! But I would go for a 4GB graphics card no question. You’ll find you need that for heavy max scenes and multiple max instances. I would also take a look into Corsair closed-loop coolers for the processors. Mine are so quiet I can’t even hear them. Apart from that it looks excellent to me.
I agree with Alex here. That machine is pretty much exactly what I have and the only “weak” link would be the video card. I would look into a 980 or something similar with a little more onboard RAM. I hope to have a new Titan Z here pretty soon for some testing. Should be interesting to see what it can do compared to our Quadro Cards.
Well the video card and the psu I already have from my old system I had to replace those parts last year so I want to keep them, its another $1,500 I can save. For the coolers I actually have a few H80s in my other systems, I wouldn’t say they are totally silent, but they are also old so maybe new ones are better. How did you fit two of them in the case though?
Also what temp is the cpu running at with full load ?
