Xfrog Plant imported
Good morning
I imported a Xfrog tree in 3dstudio.
The map ID of the trunk I have trouble.
Maybe I have to separate the object trunk?
Or should I work better on UVM Maps + Material ID?
Raf
MaxScript Detach byID : 2006-10-20
http://www.scriptspot.com/3ds-max/scripts/detach-by-material-id
Trunk element “script” - detach byID
Bitmap —> Coordinate Mapping : Explicit Map Channel
UVW Map —> Parameter : Box
Oleander
I have to review the mapping of the flower - leaves shadows incorrect
Good lunch
in early
Raf
BS09_Oleander
CoronaScatter
CoronaProxy
I enter the proxy object and render it does not appear like the original
There is a passage to follow?
have you assigned it the original material?
CoronaProxy
You are right … I had to assign the material. Perfect!
Thank you very much Ondra
Greetings
Raf
Xfrog object exported from 3DStudioMax in. obj (correct mapping) without the use of the modifier UVW Mapping.
Maps generated with CrazyBump
PT + PT
Sampling : Pts 16 Msi 7
Post processing : compensation -3,5
Hi, I imported an xfrog tree but when I scatter it with corona, it separates the object in leaves, trunk and roots and scatters them differently. Any ideas?
I once had this program, but it seemed odd to me. Especialy that there were so fiew tutorials, is it worth trying again?
The trees are great, I used some of the free ones. But I have this scattering problem. I think I have to use a collapsed mesh or their obj format
Hello
..XfrogA5Win32Max9.dlo ( to 3dsmax 9 ) —> import .xfrog - export .obj
Regards
