after couple a times of trying, i got an image like below.
back side materials screwed up. just only one side mapped when imported.
did i do something wrong in max or is this bug of sr1?
Re: xfrog trees..something wrong?
any idea?..nobody?..
are you using SR1?
thanks, Free Agent ..
yes, sure..
but, im trying to render samethings in v1 too and got same results..
are you replacing any texture? because i got that one once, when i replaced TIF for JPEG, i solved it by linking the TIF but after that changing the linked texture to the JPEG on the materials menu only, not in sketchup materials.
thanks, nektares .
im gonna explain my process.
1.in xfrogtune…export obj.
2.in max…import .obj and .mtl
when import .mtl, errors occured. so theres no map imported.
apply jpeg and test render. render result is good.
export .3ds
3.in su…import .3ds
pick the leave in material tab of su and apply to model.
apply alpha in su material.
4. render…results above showing.
any problems in my process?
very different to my process, i do this:
1.in xfrog 3.5 export to .3ds to the folder with the maps.
2.in su import .3ds
3.link the .TIF and replace linked material with JPEG format and add Alpha
4.render ![]()
thanks, nektares
the process discribed above, i searched threadsof the exsampes of xfrog trees in the gallery.
anyway, ill try your method and post the render results.
btw, “3.link the .TIF and replace linked material with JPEG format and add Alpha” means
to “do that in the material tab of vfsu” ?
thanks again.
ps. i wanna get advices of Free Agent, TOO.
oh these xfrog trees are fascinate me…
the problems of first image shows that uv mapping scale of front side is defferent to of back side.
im trying to import .3ds file made by nektares method and render again, i got same results.
thanks for your explanation
howard hong: Can you explain how you did it?
IM BACK!
SPECIAL THANS TO NOMERADONA AND STEFANG FOR MY COME BACK.
BTW, CHECK THIS LINK.
http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=12876&st=0&sk=t&sd=a&start=15
Congrats Howard!
What xfrog app. did you used? XfrogTune or the xfrog 3.5 software?
mainly Xfrog 3.5
cause Xfrog 3.5 can reduce polygons like Xfrogtune do.
and it can export .3ds directly.
most of all, i can change the shape of trees as i want.
