When I batch render, my XGen archives don’t show. Is this a known limitation? Vray 3 Mac
Hello!
Have you read the docs about XGen in V-Ray 3.0 here?
Maybe you haven’t exported the patches of the descriptions in the scene for batch render (XGen window → File → Export Patches for Batch Render).
Are there any errors in the output?
Ah, thank you. That did it. I did go over the XGen in V-Ray docs, but obviously not well enough.
Beware also that if you apply xgen to a referenced geometry that uses namespaces it will cause to render without xgen instances in batch, while render fine in the VFB.
