XGen hair not rendering with DR enabled in V-Ray 7
XGen hair will not render when DR is enabled. (It doesn’t matter whether there is a render server or not.)
Tested with V-Ray 7.10.02 and Nightlies 7.10.03 (Maya 2025/2026 win11)
The following warning will appear:
[18:39:39.414] Warning : GeomMayaHair pPlane1_description4Shape@collection3@description4 @xgen_patch: map channel Bison_Tip_Color (2) at time 1.000000 should have 0 strands, but has 251 strands
[18:39:39.415] Warning : GeomMayaHair pPlane1_description4Shape@collection3@description4 @xgen_patch: map channel Bison_Root_Color (29) at time 1.000000 should have 0 strands, but has 251 strands
[18:39:39.415] Warning : GeomMayaHair pPlane1_description4Shape@collection3@description4 @xgen_patch: Trimming to 0 strands, 0 vertices
Has Chaos support seen this post?
I’ll take a look today. Sorry for the delay.
Tested it on a simple scene, and it seems to work properly. I guess it’s something specific. Mind if you attach/send the Maya scene?
Sorry for the late reply.
Here’s a screen capture.
I’ve attached the Maya scene data (I don’t know if it makes sense)
maya_xgen_issue_2026.zip (15.5 KB)
Thank you. The issue is reproducible, and it appears to affect only the “Use Local Host” option in DR. I’ve logged it (internal tracker ID: VMAYA-13684) for dev investigation. For now, disable the “Use local host” option when using DR to render xGen.
