Currently I am using MAYA 2016 Extension 1 SP5 and I followed all the instructions on batch rendering xgen like exporting patches and adding an additional frame to the end frame of my patch export but for some reason it will only render one section of the fur.
Does anyone know how I can resolve this issue?
Are you having this problem when rendering locally or is it on a farm? or in DR? Any chance we can get a (sample) scene so we can take a look? Basically it should work right off as the instructions say.
Also what V-Ray are you using?
I am using Vray 3.1. I can preview render the scene but when I batch it locally and in the farm the fur does not render as a whole. Unfortunately I can not give a sample scene because of NDA’s we have signed. I have multiple meshes connected into one collection would that cause an issue?
XGen Version: C:/Program Files/Autodesk/Maya2016/plug-ins/xgen/ Build Date: Nov 30 2015 12:10:16
Error: XGen: Alembic error. No geometry named ‘xgen_feather_tail_a_shaft’ found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
Error: XGen: Alembic error. No geometry named ‘xgen_feather_tail_b_shaft’ found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
Error: XGen: Alembic error. No geometry named ‘xgen_feather_tail_c_shaft’ found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
Error: XGen: Alembic error. No geometry named ‘xgen_back_headFeather_shaft’ found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
Error: XGen: Alembic error. No geometry named ‘red_hi_cn_body’ found in file(frame): M:/directors/peter_sluszka/mcds38/mcds38_angrybirds/06_3d/maya/lib/char/red/components/fur/workshop/red_fur_workshop_0055__redCollection.abc( 5.0000)
Warning: XGen(1): No pref specified for: XG_RENDER_:xgen_feather_tail_a_shaft. Popping may result.
Warning: XGen(1): No base geometry specified for: XG_RENDER_:xgen_feather_tail_a_shaft. Cant render patches on this geometry.
Error: XGen: Caf Error. Removing patch: XG_RENDER_:xgen_feather_tail_a_shaft
Warning: XGen(1): No pref specified for: XG_RENDER_:xgen_feather_tail_b_shaft. Popping may result.
Warning: XGen(1): No base geometry specified for: XG_RENDER_:xgen_feather_tail_b_shaft. Cant render patches on this geometry.
Error: XGen: Caf Error. Removing patch: XG_RENDER_:xgen_feather_tail_b_shaft
Warning: XGen(1): No pref specified for: XG_RENDER_:xgen_feather_tail_c_shaft. Popping may result.
Warning: XGen(1): No base geometry specified for: XG_RENDER_:xgen_feather_tail_c_shaft. Cant render patches on this geometry.
Error: XGen: Caf Error. Removing patch: XG_RENDER_:xgen_feather_tail_c_shaft
Warning: XGen(1): No pref specified for: XG_RENDER_:xgen_back_headFeather_shaft. Popping may result.
Warning: XGen(1): No base geometry specified for: XG_RENDER_:xgen_back_headFeather_shaft. Cant render patches on this geometry.
Error: XGen: Caf Error. Removing patch: XG_RENDER_:xgen_back_headFeather_shaft
Warning: XGen(1): No pref specified for: XG_RENDER_:red_hi_cn_body. Popping may result.
Warning: XGen(1): No base geometry specified for: XG_RENDER_:red_hi_cn_body. Cant render patches on this geometry.
Error: XGen: Caf Error. Removing patch: XG_RENDER_:red_hi_cn_body
