Xpresso/Tracer Object Crash Scene while using IR
I was trying to use a project that has a complicated Xpresso setup and it seems it causes the viewer to continually run calculations that that eventually forces it to c4d to crash.
While trying to figure out the issue I used a couple of the c4d example projects with other setups and those also seem to be crashing as well. Some thought it seems the tracer object actually causes the update to happen continually others it’s clearly an Xpresso problem since it seems to work fine after disabling them.
I have been able to reproduce the issue multiple times in R19 broadcast and R20 studio on windows 7.
Some of the scenes I tried where the sound example projects as well as some of the tp example projects like tp_surface_emitter(tracer crash in this one). I can send my bug reports directly or example scenes.
Also, I have seen some mention of this but I’m not sure if a solution or a workaround has been found or is currently being worked on.
Hi there, the best way for us to determine what exactly is going on and the root of the problem would be as you said to send us a sample scene and include your bugreports and .dmp minidump file. Once we have it, a more detailed response can be given. If you need to use our private uploader, you can find the link in my signature below. Thanks,
Uploaded a zip of my whole bug reports folder with the projects all the project files that crashed.
1544101486_GB-bugreports.zip
Thanks!
