XRef materials not rendering
It seems that if an object is an xref and the material is an xref also, it doesnt render in 1.6.
Is this an issue youre aware of? Seems like someone will have brought this up by now?
J
not aware of this, there were some previous xref+mtl issues reported, but they turned out to be user errors. we will investigate it.
Ah ok, a little more detail from me.
The object itself is an xref and the material in the palette shows as an xref material too. Currently it doesnt render the bitmaps if thats the case, colours seem to be fine but i might be wrong on that. but everything just defaults to a standard grey when the materials are xrefs. Once theyre merged, everything is fine.
