Xref Object and Corona Scatter
When I bring in an xref object that contains a corona scatter, it does not render. You can see it in the viewport though.
Corona 4 Build Apr 5 2019
3ds max 2019
Hi, thank you for reporting this to us. We have confirmed the issue and will look into it.
In the mean time, referencing the whole scene is working correctly. Do you think you can use that as a workaround for the time being?
Thank you for your patience
(internal tracker: 345095762)
