XRef object with multi/sub material problem
Hello!
I have a little problem when i xref an object with multi/sub material on it.
When i xref it its looks perfect in viewport, but when i render, its look like every object or ID use the first slot in multi/sub.
I attached a test file. If anyone xref it, its looks same? (whole object red in this case)
Tryed other render engines and works perfect, only mess it up in corona.
Thanks for help!
Gabe
xref_test.max (1000 KB)
Yes, here it looks like you described it. Xrefing the scene works, xref object not. Merging the xref material into the main scene gives the correct result. So it seems to be a problem with the xref material.
Good Luck
Corona 1.4 | Max2016
Duplicate Xref Material Override Not render IDs multsub materials - Corona for 3ds Max :: Issues - Chaos Forum
and still present in 1.5.2
Good Luck
yeap! same thing happening here as well! pretty basic functionality doesn’t work
had to go with v-ray for the time being, sending 900 jobs to backburner manually was not an option
duplicate: Xref Material Override Not render IDs multsub materials - Corona for 3ds Max :: Issues - Chaos Forum
Grrrr, just came across this problem and it’s super annoying!
Need to finish a job with another modeler by the end of next week and all I’m getting is ID1 in the renders O_O
What do we do? Xref is the way to go for us, but the materials aren’t rendering properly :frowning:
EDIT: Figured We’ll have to rely on material libraries for this one. Save, package, open, merge back in…
I still have the same issue in Corona 1.6 :frowning:
Pretty annoying.
I want to fix this for 1.7
The problem is solved in 1.7?
hi, not yet, we had to move it back to v2
