hai all .. is there anybody using xref scene? usually for me, i use xref scene to put anoter high poly object (trees, envi, etc) to be xref-ed .. but when i render, it doesnt appear .. ![]()
please correct me if i am wrong ![]()
this was already fixed and will be corrected in the next release
Have this Xref scene problem been solved in the current public alpha release, or only on daily builds?? Because I have the same problem as the others - Xref scene doesn’t work but Xref Object does. See attached screendump.
I have taken the risky jump to try to make a current project using Corona - as it has some really good and useful features i need fo this project, and now I am a little set back because of this problem.
But really I am so excited about this render!!!
ALl the best - and please help!
CoronaXrefTest.zip (47.5 KB)
no, this was fixed after Alpha v5, so it is in the daily builds only
OK, can I do anything to get access to the daily builds that fix my problem?
I have just started working with Corona and haven’t any real nice images yet - that was the plan to do with this project actually.
I have made a WIP post in the gallery though - hope it show my right intentions - and you will have mercy with me.
My WIP post:
you need one more post for seeing the section with daily build. As per the activation, I guess finding a bug, even fixed one, counts ;). So go ahead
Arrrrgh!! you are a tough guy to deal with Keymaster ;O)
So here you have it …
- this was my second image made in Corona - lots to come!! Especially when I get a version with the Xref scene bug fixed
I feel like an addict begging for one more fix … to take me to heaven!
