Xrefs - Chaos Cloud
Rendering Jedi’s
I tried searching but did not come back with anything. I am bit new to the process of submitting to the cloud. Curious: I have a few xrefs linked to my main scene. Is there anything I need to consider when sending it up to chaos cloud? Or did I just send it normally? Or do I need to collapse the xrefs into the main max file? Thanks in advance.
Murphman
Hello there,
Xref files will work with Chaos Cloud. It actually uses vrscene export that will export everything that is unhidden in the scene, just be sure that all assets are in a reachable location from the workstation.
In case you are having any issues while you submit your scene, please use the report button in Chaos Cloud to report the specific problematic job.
Thank you - I tested the job and yes everything worked. I appreciate the response.
