Yacht Render
how i can improuve the realism of this render? thanks
Re: Yacht Render
i’ve changed the render, please help me :slight_smile:
Re: Yacht Render
It’s not bad so it’s hard to make it better. May be that’s the way - make it less perfect (reflections, colors). BTW the light tubes are gorgeus, how did you do tham? (I’m supposed to make some interior lamp for exams :slight_smile:
Re: Yacht Render
Thanks man :slight_smile: For neon lamp, i follow the tutorial on evermotion (self emittent light tutorial)
I’ve improuved something, added air-intake in black…
it’s better?
Re: Yacht Render
I like the second one because of colder feeling but the first one has a better view. May be you should fix antialiasing and glossiness a bit.
Re: Yacht Render
how i can fix antialiasing?
i use LANCZOS 1.5 size
Re: Yacht Render
LANCZOS is a sharpen filter and this will cause more visible aliasing. Most I use no filter or area 1.2 .. 1.5 (light blur). I belive, strong sharpness and high antialiasing are not possible or not easy to get.
Also you could render a bigger image size with less strong noisethreshold and downesize the image later - maybe this will bring a better antialiasing, dependent from the downscale method (I don’t tested it, but would try it, if I need it :wink: ).
