Yet another Material Preview Issue
Every time we switch back and forth between two scenes, the node materials are re-rendered. This can take a long time depending on the scene. I noticed that it only happens when VRay is set as the render engine. Normal node materials with default engine does not re-render here. Is there a way to freeze the preview of a material or to fix the problem in general? The standard VRay materials do not re-render.
Translated with DeepL
Hi @Doger , have you tried the V-Ray 6 for Cinema 4D beta? We did a little fix for the node material previews refreshing too often that will probably fix your case as well. We will be backporting the fix to 5.2 soon.
Hi @deyan.hadzhiev thank you for the quick reply!
I just tried it with the latest nightly of the VRay 6 beta. Unfortunately, the problem still seems to exist here.
